Recently I got a local carpenter to produce a set of stairs for my house. It is to go into an existing house and has been fabricated together as one long flight of stairs, a 4 tread/step corner piece, and one stair on landing. However we are going on holiday soon so we've asked him not to install the stairs/cut hole in floor above until after we get back in a couple of weeks time.
Over the weekend I went to check it out and did some some measuring and after some measurements I had a feeling that the stairs looked a bit too long given the tight space we need to install it (2.1m along long side of L-shaped staircase and can't be longer due to proximity to kitchen door in floor above). The long stair slight has 8 steps with riser 185mm and going of 240mm. We live in England and building regs state that headroom clearance is 2.0m to step directly below. I used AutoCAD to design up stairs produced and the 2.1m hole length required and I am now certain it will not achieve the 2.0m clearance. However when I spoke to the joiner (who has 40 years experience), he says it will be fine and comply with building control.
My question is, given my uncertainty of it all (mainly joiner starts cutting holes in floor and realises he has made a mistake), what is the best way to go around this to make sure that it it is not the correct size? Is it also possible to reduce the long stair flight in length from 8 steps to 7 steps (which will in my opinion comply with 2m clearance) without starting from scratch?
