Return and flow on rad valves
Discussion in 'Plumbing and Central Heating' started by Jibbs, 30 Jan 2013.
  1. Jibbs
    Jibbs
    24 Jan 2012
    66
    Thanks Received:
    2
    South Glamorgan
    Country:
    Hello all
    Just a quick question. Does the return/ flow have to be on a TRV valve or does it now matter?
  2. Sponsored Links
  3. mrnigelhudson
    mrnigelhudson
    30 Jan 2013
    12
    Thanks Received:
    Manchester
    Country:
    Most of the TRV's now are multi direction so it should not matter
  4. Jibbs
    Jibbs
    24 Jan 2012
    66
    Thanks Received:
    2
    South Glamorgan
    Country:
    Okay cool but say i was replacing a rad and the two valves how would i determine which was the flow and the return. Obvious answer i guess is see which one heats up first.
    Was just wondering if flow/ return had to go into TRV.
    Thanks for the info
  5. Whitespirit66
    Whitespirit66
    15 Dec 2007
    8,012
    Thanks Received:
    755
    Bristol
    Country:
    If you're fitting a TRV, one of them will have to go to the TRV. :confused: Not all rads need a TRV, usually the rad(s) in the room where the stat is shouldn't have one.
    Most TRVs are bi-directional. Some like the Danfoss RAS range have a grey collar on them under the head that you turn to set it as flow or return.
    Yes, the only reliable way to tell the flow and return apart is to see which one heats first. Unless you can trace the pipes back.
    • Thanks Thanks x 1
  6. Jibbs
    Jibbs
    24 Jan 2012
    66
    Thanks Received:
    2
    South Glamorgan
    Country:
    Thanks Whitespirit
  7. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    And there was I thinking they were only bi-directional. ;)
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
