reverse lights on voyager
26 Feb 2009
Cumbria
hiya
have an 02 plate voyager, the reverse lights have stopped working. have checked the bulbs which are fine! thought it might be the fuse but cannot find fuse for reverse lights (in the relay box under bonnet) is there a fuse box in cab? any other ideas ?
any help appreciated
as above.
easy way to check is to remove the 2 wires from the switch and bridge the terminals with a paperclip, put the car in reverse and switch on the ignition. If you have lights then the switch is duff
cheers !! do i get to the switch on the gearbox from underneath or can you get at it from above?
Not familiar with it, but should be underneath.
As it's quite modern, there may be more than one thing with wires going to it.
You want the one with 2 wires. If there is more than one, then it's a bit of pot luck unless someone else can answer!
