Hi guys,
I have been using this forum since we moved house,and took on a complete internal rebuild
it didn't look that bad when we viewed it,honest
well,I am contemplating having the house wired,the reasons are as follows
1: some rooms only have one socket the hall doesn't have one at all ,and there are holes in the walls where extension leads have been run through,to get power there.
2: The whole ring main is on one breaker in the fusebox.
3: The lighting circuit is also on one breaker in the fusebox.not so much of a problem as all the room just had a single bulb,but most have 3 or more now.I know the upper and lower floors could be separated easy enough.
4: the fusebox is an old one with only a few breakers in it,so will obviously need updating.
5: The wiring circuit is wired up a bit wierd as sometimes there is just a sheathed single red core wire to the switch,or to the light/switch in the next room,maybe this was just a quick/lazy of wiring up.
The wires in the house are all relatively new looking twin & earth,as all the old wiring was still up in the loft.I replaced all the upstairs lighting circuit when I moved in as I re-positioned all the lights.
6: The ground floor is concrete,so I realise all the wires will probably run through the floor boards of upstairs and drop down the walls to the sockets.
7;there are currently two 500watt outside lights up and sometimes they are both on together,with some of the house lights
I am removing these lights and these are getting replaced with something a little smaller and more effecient.
8: after a year and most of the walls bare,I am in the ideal position to get it rewired,but have I any more cost friendly options.I would be looking at helping out as much as possible to keep costs down,and to learn a bit in the process...
I have only had one quote,and this was for £2,500,and this didn't include plastering the chasing out,after the wires had been laid.
I have found this forum a wealth of knowledge especially in the electrical department,and has helped me out on numerous occaisions
P.S will all the sockets go at the new required heights now or could I keep them at the height they are at now?
Darren
