Riello rdb burner
14 Jan 2016
Hi, i have Worcester greenstar heatslave 18 oil boiler, the last few nights the main rcb had tripped i reset and all fine but went off again overnight, could this be related to my burner randomly not firing? I'm gas safe so tested all components in the boiler ok only thing really is the burner, i cleaned photocell but cant check capacitor as its right inside the boiler. It does fire up mostly though, any thoughts?
snb
10 Oct 2007
Norfolk
Your gassafe! But can’t check capacitor. Not difficult. Remove red burner cover capacitor is attached motor. Very easy to check.what else have you tested?
14 Jan 2016
I didn't want to go poking round insife the burner as its hard to access, I've traced it back to faulty 2 port, noise was pipes vibrating due to bypass
29 Nov 2009
Shropshire
So you've sorted the banging out. This will have no bearing on the burner lockout. A good service is required.
