Hi
I have an external light run on an existing cable. I have replaced the bulb in the light with hive smart bulb. As a result I leave those light switched on from the switch and turn the bulb on and off via my smartphone
I want to install a Ring floodlight cam. My plan was to use the same wire to power it. ie cut the wire, use juction box etc.
Is there any reason this would not work?
Thanks.
Thanks.
