RING DOORBELL PRO - can I use a plug? or need transformer?
20 Dec 2013
London
i have no existing doorbell....i want to get the pro cos its hardwired and my consumer unit it close to door.
but how easy is it to connect it all up? does anybody have any experience?
electricians are charging £200+!
the doorbell cost £140!! :D
so i want to see how easy it is.....
from what i understand the transformer goes in the consumer unit.....
and then i have to somehow join it to the bell.....
i cant find a video on YouTube showing setup without any doorbell in place...
also has anybody got any experience with the plug?
it would suggest no transformer or anything else is needed!!
https://www.amazon.co.uk/Doorbell-A...ocphy=9045888&hvtargid=pla-789018218049&psc=1
but apparently they get very hot so would rather hard wire if its not so complicated.....
Perhaps someone with specific knowledge of the product will come along later, but from what I can see online, if this is the product:
The instructions appear to be American, and do all seem to concentrate on replacing an existing doorbell, so the transformer will not go in the consumer unit in the UK, but can be placed next to it, or anywhere you want.
Then you will need normal mains 240V cable from the CU to the small transformer - you could run it off a lighting MCB - and then suitable two-core cable to the large transformer/chimes and then on to the doorbell.
The plug-in device in your original link will not be needed.
yup instructions are garbage
from what i understand in UK we do need to put the transformer into the consumer unit. need 2 spare slots
the plug option was just an alternative solution as im capable of plugging something in myself :D:D
Best to install that in a separate 2-way mini DIN rail box. Power it then from wherever is convenient.
cool thanks
Does anybody have experience of actually fitting the doorbell itself and can share??
theres a pro power kit included too....i just want to get an idea of how to actually install it from transformer in fuse box to bell outdoors....
I thought he had space in the CU!
There are many wall-mounted transformers available. You don’t need a DIN rail one and then have to buy a separate box!
If one could be certain the OP would employ a competant electrician to work in the consumer unit then fitting the transformer in the CU is an option.
BUT when the transformer is fitted in the CU there is no provision to isolate the transformer without switching OFF one of the MCBs ( the one feeding the transformer ) which would mean some circuits ( lights ) would also be OFF. ( If there were three spare slots then an MCB dedicated to the transformer could be fitted.
There also the consideration that as the transformer is not a part supplied or approved by the CU manufacturer then the type approval of the CU could be compromised. This could complicate / prevent an insurance claim for damages due to an electrical fault.
If one could be certain the OP would employ a competant electrician to work in the consumer unti then fitting the transformer in the CU is an option.
There is no requirement to say that only a competent electrician can carry out work in a consumer unit.
He can do it himself, if he takes adequate precautions.
