Due toaconversion going on at home I need to move a double socket from a wall that will eventually be knocked down. All the cabling in this area was accessable apart from the feed going to the next inline socket As space was tight and a sleeper wall exist's between the rooms and I don't need the socket I have pulled the cables under the floor and re connected them using 30 Amp connector block. I have also placed the connection inside a IP65 rated inclosure fix to a joist. The question is have I done anything wrong as safety comes first.
