Ring Main Wiring Question
29 Jun 2008
Tyne and Wear
First post here, and great site by the way.
In one of the bedrooms I am adding an additional power outlet. On lifting the floorboards I found (conveniently!) a junction box. It looks like the ring main has been spliced and a spur taken off to the other side of the bedroom for the power outlet there.
Is it okay for me to take a spur off this i.e. ring main with two spurs, or should I be doing something else?
Cheers,
Dean
why not make the new socket part of the ring (and the other one too)
Thanks for the quick reply!!
Because its an old house with really high floorboards with megathick plaster, which I have found out makes a total mess!! (isnt chasing out brick fun, not!!), and there is already a small hole I can use for routing the cable.
I admit this would be the ideal choice, but just wanted to check its legal and good practice to have multiple spurs off a junction box. I believe I use minimum 2.5mm cable.
Desn
its bad prctice and not allowed, which is why i suggested as i did
Thanks, thats what I wanted to know.
Should I remove the original spur as well, this will be a real bugger as its plastered halfway up the wall so would have to be chased out.
Dean
You could keep the existing spur as it is to avoid chasing out plaster. But run two 2.5 cables to your new socket and wire it in as a ring. You'll need two JBs next to each other, unless one of the ring legs can be re-routed to your new socket in which case do that.
Thanks for the advice. Removed the spur and connected the ring main to the new outlet.
First time plastering too, what a messy job.
