Ripped wallpaper - any advice?
21 Jun 2006
Plymouth
My son has just taken a small area of wallpaper off my newly wallpapered hall! It is quite noticeable, just wondered if anyone has any tips for making this less noticeabe???
Put a bigger piece over the torn piece..held on with a but of adhesive then cut through the two pieces...remove the outer part of the top piece and the piece directly beleow it..including any backing paper and it should fit a treat.
Take a piece of wallpaper and tear it to any shape but large enough to cover the damaged area, you will then end up with a feathered edge stick the patch onto the area to be repaired matching any pattern.
Agree
and the irregular torn piece will not catch the eye, like a square or regular shape will.
