I'm a bit confused about how Section H1 covers ground floor toilet drains, specifically about clearance of blockages. I gather H1 is aimed at the drains downstream of the soil vent pipe, but assume similar requirements apply to ground floor (underground) laterals? Paragraph 2.46 begins with "Sufficient and suitable access points should be provided for clearing blockages from drain runs which cannot be reached by any other means." . Would 'other means' include moving the toilet pan and rodding via the open pipe end? What if you have a wall hung toilet that can't be easily moved? I've seen plenty of ground floor toilets before but never with an inspection cover inside the house.
