Roller blinds strap or wall
27 Jan 2013
Hi
I’ve just had recently skim plastered walls done. What’s the best method to fix roller blinds?
The rollers are not recess fit as the windows are tilt n turn, so hang over.
option 1 fix a wood strap onto wall and secure blind brackets
option 2 fix bracket straight to wall, brick and plastered walls
it's basically up to you! :)
Adding a wooden batten allows some flexibility in where you put mounting holes; useful if you start to drill in one place and find a loose area that a wall plug won't stay in.
It also gives you flexibility if you mess up the bracket spacing; you just rescrew them into a different part of the batten, rather than having to redrill the wall.
The batten can also be reused if you decide to mount a curtain rail at a later point.
However, the batten will take the brackets, and hence the roller blind, further away from the window; possibly affecting privacy and shading.
