Roof leak - deteriorated membrane or valley mortar?
1 Nov 2026
Following heavy rain and strong winds recently, water has started coming into the property. We have had the felt around the box gutter extended, as seen in the photos.
The same roofer has now advised the membrane is deteriorating, there are rips and holes in various places and it stops short of the valley. They have recommended a full membrane replacement.
I’m just keen to understand whether this is necessary and will fix the issue of the leak. Another roofer has said the mortar needs repointing and one of the tiles falls short of the valley, so needs to be replaced. The tiles can be lifted away easily at the moment and that shouldn’t be the case.
I’m wondering what needs doing. Repointing or new membrane.
It's a tricky area, it's looks like a bit of a bodge.
The membrane certainly looks rough, I wonder how that hole appeared? Looks like it been poked in.
There's white blob of what could be cement or silicone sealant, certainly not appropriate here.
Get another roofer out there have a look, ideally someone who specialises in leadwork, that's what it really needs, up the wall right up to the coping stones and well underneath the tiles.
Your roofer might not be the best in town.
Felt is dressed up the parapet without any lead covering, is there much of a fall on the flat roof area?
The valley tiles look to be quite close . To be honest it all needs striping right back and renewing properly.
Is it possible to remove the parapet completely and just have a flat roof section.
The under felt looks like BS 747 1f which is quite old but there are still roofs without felt and if in good condition do not leak
What is the purpose of that God awful parapet, other than to obstruct the natural flow of water?
That valley looks very short on Lead (or fibre glass). You need to get a couple of good builders to advise and quote.
