Roof ridge tiles need replacing
25 Apr 2019
Hi all,
Is this a DIY job please? My current ridge tiles are cemented but it is breaking up and I can see gaps, is it a DIY job to replace these with the dry ridge type solution and what's involved please?
Its for my single story kitchen so access is quite easy.
TIA
Hi all,
TIA
Retro fitting to mucky tiles can be a chore. The roll-out ridge cap fixes to the tiles with a tacky peel off adhesive layer. Plus you need to add a ridge timber to the peak, an this involves removing the first course of tiles (if you use the dedicated brackets - truss roof) or you need sufficient tile gap to fix some 45mm x 45mm tanolised timber to to the ridge board.
All this whilst balancing on the ridge. Plus you need a driver and possibly an angle grinder. How steep is the pitch? Is it a concrete tile roof? Is it a truss rafter roof?
Picture shows better
I would just take off and re set in m
New mortar mix 3 to 1 with sparp sand. Do one ridge length at a time and use a long straight edge to keep them straight.use a stiff mix but wet the old tiles wher the new mortar is going
