Roof Seal
20 Sep 2004
Hi
We are thinking about getting our roof sealed, however, I would like to check to see if there are any benefits to getting this done. What type of guarantee should we look for and what should we look for from a company doing this type of thing should we choose to get it done,
Thanks in advance for any advice,
Mandy
do you mean the spray on expanding foam stuff?
if no what then
if yes, don't
it seems a good idea, how ever no one can say how long it will last becasue it hasnrt been around that long as a roof sealant, spray foam does deteriate over time.
also as it seals the roof it lets no air in or flow so beams get rotten /or what ever they do with no air flow
the man breezer is dead right,plus,i'm assuming the roof isn't felted,what do you do if you get a broken tile or slate,your whole roof is bonded together with foam,how do you remove a tile/slate without damaging the foam and nullifiying any guarantee the foam company has given you.my advice to you is to look for alternatives and AVOID SPRAY FOAM LIKE THE PLAGUE.it will probably cost as much as it would to just stick a new roof on.hope this helps.
