Hi. My house is a detached, rectangular property with what I think is called a truncated hip roof. Effectively, all four sides of the roof slope towards each other, meeting a large, rectangular flat section instead of meeting at an apex.
The house was built in the 1950s and then extended before we purchased in 2007. As part of the extension work, the previous owners replaced most of the roof, but left some of the old roof intact. See pictures below of what they did.
I've never been terribly happy with this, but it hasn't caused any problems for the past 18 years so haven't worried about it. Anyhow, directly beneath where the old section meets the new section of roof is my sons bedroom and over the past 12 months, a crack at the junction of the wall and ceiling has appeared and gradually gotten worse. Not terrible, but there's clearly something going on.
I had a local roofer come to have a look and his concern was the unsupported cut-off purlin. He also didn't like the old 4" x 2" timbers and has suggested a remediation plan of strengthening all of the old timbers by bolting new timbers to them, essentially doubling up each rafter. This all sounds sensible to me, but having had another look at the roof, I remain concerned. In the second picture, you can see that the ceiling joists run perpendicular to the rafters and therein't any visible tie between the ends of the old rafters, and the ceiling joists. I'm no expert, but I'd imaging that this could be a partial cause of the cracking? Interestingly, even some of the new rafters are also not tied to joists, although most do as the builders installed new joists to tie everything together.
Bottom line is, I'm looking for some advice on what I should do. Would simply doubling up the old rafters help? Is it a problem that the (old) rafters aren't tied to anything at their base?
Appreciate any views. Thanks!
