I recently had a new 7 day programmer (Honeywell ST9400c) and a room stat (Honeywell T6620B) fitted to my gravity fed system. These were replacements for older models.
At first worked ok but then the fuse in the switched fuse to the programmer started blowing on operation of the central heating. Did not blow until set the room stat to 21degrees. Replaced fuse(s) and had 2 or 3 days when fuse didnt blow. Has now reverted to blowing the fuse every time I switch the central heating on!
The water heating works fine as long as I dont start the central heating.
Could someone help and advise me pleae? Is this a fault in the room stat or the programmer? or could it be a fault in the pump or a zone vave? No problems till I changed these 2 items.
