Room thermostat not connecting to CH boiler
23 Jan 2003
Hi my room thermostat (old type) clicks when I turn it but does not stop the boiler heating the rads whatever temperature I choose.
Photos attached. Any ideas please. All connections to the thermostat are clean and tight
Not sure what a live tester is. If it's a voltstick or similar it won't help. It could be the thermostat has failed, it could be the link is left inside the boiler. Probably going to need a gas safe registered engineer for this one. For the time being you can select hot water only on the boiler to cease firing when heating isn't required
does the heating go off when the clock/programmer is set to off
with clock off and stat turned down can you put a pic up of front of boiler and what its doing.
And as per country fan do you just have one stat as in you dont have separate controls upstairs and down stairs or underfloor heating ?
Next time I’m at the property I will take a pic.
Only one room stay and no underfloor heating.
Would the individual stats on the rads influence anything??
This video
explains how the motorised valve works. 5:37 shows the switch, the thermostat or programmer works the motorised valve, and in turn the valve works the boiler, so if the micro switch sticks, the boiler will not turn off.
My boiler had the same problem, I unclipped the head, gave it a sharp tap on the cupboard base where the valve is hidden, and it freed off and has been working for a year without sticking again.
next time you are there disconnect the live red wire in the stat safely so no one can touch it .....
If the boiler still stays on then its an internal fault on the boiler
There is the possibility that the thermostat is from a previous boiler and may not actually be connected anymore.
I've come across a few boiler swaps in the past where when changing to a combi, rather than pay to employ the services of an electrician, the gas installer has simply connected the combi boiler to a permanent live supply. Leaving the old controls in place but not actually doing anything. This shouldn't happen now though as building regs require all boiler replacements to include controls.
You don't say, but I assume it has never worked properly rather than this being a recently occurring fault.
