Hi
Continuing on with my 80's dormer renovation I've discovered some rotten joists whilst pulling down a ceiling in the lower part of the house.
The house is built on a slope and the front door is on the 1st floor, accessed from a deck that juts out from the front of the house. The deck is suspended on joists. 1 third is over the lower hallway (which is where the problems lie) the remaining 2 thirds are the garage.
(the scaffold us not up anymore it's an old pic to show the house construction)
When we purchased the house the previous deck, made up of some kind of mortar and tile construction was letting in water in numerous places. We had the deck replaced with an epdm flat roof with composite decking on a floating timber frame on top.
So the construction now is composite decking, epdm covering, 18mm osb, 25mm floorboards then the joists.
Problem is the company that did the work replaced some of the joists at the other end of the deck, but now I've found the other end all the joists are rotten to varying degrees. I obviously do not want to disturb any of the deck so I want to replace/repair the issue/damage.
I've been researching options and it looks like replacement, sistering or Bower beams plates could be an option.
Here are some pics to give an idea of the issues
This is the worst one, I can push a screwdriver through the top along the top approx 500mm
These joists look terrible but are not soft,
This is the worst joist from below, its not square and is angled over, looking at the bricks and mortar at the end it looks like it may have been like that since installation? Should I remove and try and square it up? Or best left if it's doing its job (kind of)?
This is the opposite ends, which continue on through to the garage, they're sat on a brick wall with the door to the garage going through
What is the best way of assessing the joists to see how much is needed to be cut out? I've been using a screwdriver to look for soft areas, all the end approx 100-150mm are soft, the rest of the joists don't look great but aren't soft. Is there a rule of thumb? IE if a screwdriver cannot be pushed through the timber its deemed OK? Or should I be looking to replace it all due to its appearance?
What is the best/easiest method to sort it all do that I'm not pulling the ceiling down or removing the deck in 5 years time?
Any other info or advice welcome, many thanks for taking the time to read my post
