Rotten porch needs overhaul - timber window frame mouldings?
30 Sep 2011
Hampshire
I have a porch on the back of my house - the lower half of the walls are brick, with timber framed windows / door making up the rest of it, and a flat roof. Pretty-much all of the timber is rotten and in need of replacing.
What I'd like to do is replace the timber framework, then install some custom (i.e. cheap, home-made) windows / frames in to the gaps left. I'm struggling to find anywhere that I can source timber mouldings to make the window frames out of though. I'm not bothered about the windows opening at all, so all I really need is a square of suitable timber that I can slot some glass in to (or maybe sealed units).
Anyone have any recommendations for where to source timber mouldings to make window frames from? Presumably I need the right shape of moulding so rain flows out rather than in as it runs down the glass.
Thanks,
Gareth
I'd simply buy squared up timber and shape it myself .To form the cill it's easy enough to just use a power or hand plane for the majority of the work and after that a couple of router bit such as a rebate cutter and a moulding of your choice.
Other than that try any decent timber suppliers who will normally supply rebated and shaped sections for a price.
Wee&Poo (b&q) and Wickes both have suitable mouldings to finish the outside, used with some putty on the inside - where the glass meets the wood. Or alternatively could just use putty.
Dont forget to use putty on both inside and outside. You can get hideous noises from mildly vibrating glass! :(
As LL says I would also use PSE planed smooth timber and create a rebate for the glass to sit in too.
