- Joined
- 13 Sep 2015
- Messages
- 335
- Reaction score
- 194
- Country
I am decorating one of the rooms in my house and want to add ethernet while I am at it. I want to bury the cable.
It makes sense to me to borrow the "safe zone" thinking of electrical wiring, so I don't undo all of my good work later on by driving a picture hanging nail into my nicely concealed cat-6.
So, I'd quite like to co-run my ethernet wiring alongside the electrical wiring in an open chase. This means the electrical socket would create the safe zone it sits in, the same as it does for my electrical wiring. Yes, I know running parallel to the electrical wiring (a 2.5mm 20 amp radial) may have a small degrading effect on the ethernet. It's only a 2m ceiling to socket, so I doubt it - but I understand the risk.
Anyway, is there any *regulatory* or *safety* issue with routeing my ethernet cable into my socket's metal back box. Basically, it'll come into the backing box from the top, taking advantage of the vertical safe zone above it, hang a left to go out through the side, then carry on the horizontal safe zone to a newly installed ethernet point.
No, I cannot just use the ethernet point to create a facsimile of a vertical safe zone and route straight to that. The location won't allow for it. My only available vertical safe zone is via the electrical socket.
So, in short: Can I route ethernet cabling through an in-use electrical backing box?
James
James
