securespark said:(as FWL would say!!)
securespark said:Remind me how long it takes to drive from N London to Bramhall, and then give a head start. 48 hours should be enough!
Inspector said:Putting trunking up may make your conservatory a bit of a dogs dinner. You could consider clipping cable directly to the surface and clipping it -
1. Unsheathed pyro has a copper finish but you'll need a good spark to do that
2. FP200 cable looks like flex but its more rigid
3. If your conservatory is not white then you could use 1.0mm 3 core flex which comes in a variety of colours
The rigidity of pyro and FP200 allows less clips per meter to be used.
Also consider wall lights on the house wall.
