Installing kitchen and aim to use exisiting circuits if possible. I have shown a diagram of the circuit to the cooker hood via an FCU
- Wire to 2 gang socket is 2.5mm twin plus earth
-wire from 2gang to FCU is 2.5mm twin plus earth
- FCU is switched and currently has 13A fuse in it (3A would be sufficient for hood).
- Wire from FCU to flex outlet and flex outlet to cooker hood is 1.5mm twin plus earth (earth not used in hood as double insulated)
-all wires are buried in the wall except for the wire from the flex outlet which runs 10-15cm down surface of wall into the hood
1) Is it ok that the FCU is spurred off the double socket?
2) Are the wiring sizes ok?
3) where the wire from the FCU goes from vertical to horizontal toward the flex outlet, there is no junction box etc here to show the change on direction. Only the flex outlet plate itself indicates the change in direction. Is that legal?
4) Is it legal to have the wire leaving the flex outlet running down outside of wall for 10-15cm to the cooker hood?
5) I take it the flex outlet has to be within 15cm of ceiling?
6) is attaching a new hood to the flex outlet wire still notifiable !?
many thanks
many thanks
