routing out a 35mm deep and 12mm wide rebate in the bottom of a hardwood door
16 Jun 2006
London
Hi all,
A customer is considering a drop down door seal.
I will need to route out a 35mm deep and 12mm wide channel.
I could use my palm router but I guess each pass will be limited to about 3mm. That means about 11 passes.
If I use my 1/2", I will need to make a support to stop the router tilting. The door was painted by me about 2 years ago so the paint is not soft. Hints for a support template will be much appreciated. Additionally, how deep can each pass be?
Tnx in advance.
never done it but my thoughts anyway
because its 38mm deep and assuming you mean a 1/2" router rather than cutter
my thoughts are say 3x1 or 4x1"par timber clamped each side so you have 80mm ish surface to run the router base on
the clamps on the bottom edge off the timber so not trying to pinch the the slot closed as you router it and clearing the guide fences
passes are normally half the shaft in depth so around 5 to 7mm
if you have a single fence then pass down both sides in a circular motion but before you do the other edge make adjustments iff required to the fence to make sure the slot is an accurate width by a slight nick away from the ends
if its an open slot i would also think about circular saw and fence again going up one side then the other moving 2mm on the fence
but as i say never done but sounds the easiest for a one off where a jig is not needed
keep in mind the fence needs to be farthest away from the cutting edge in direction off travel as the blade will try and drag the machine a bit sideways
Americans use a wobble blade in a circular saw. I've never seen it done here.
You could use a plough plane or combination plane. I imagine you'd do the two saw cuts first.
I got a morticing jig recently, but it is not intended for such a long cut.
many ways really
saw cut to form the trench sides then sharp chisel cutting in from the ends in with say 5 or 6mm slither although that wont work into the styles
as its only 14mm wide and assuming a say 1.7mm blade then 1.7slot then reposition 3.5mm so 1.7 then a 1.8mm feather then 1.7 then another 3mm do that down both sides just 2 or 3 repositions off the fence required then easily clean out the channel with a chisel
