RSJ Calcs
11 Jan 2004
This may be better in building but here goes...
Could 5.03m be spanned with one run?
The steels would be supporting a once-external cavity wall itself supporting joists and a pitched roof above.
It would be slightly longer if the steels were supported by the cavity wall either side, instead of resting on piers.
Or would I need a pier in the middle of the span?:(
I take it your knowledge of steels and their span is like mine, then?
I dunno, I seem to remember in a domestic dwelling, the span is limited.
Mine came today, it's spanning 5.04mtrs:
You can span in excess of 20 m with a UB dependent on load but I think for you it'd be be limited to what your can beam you can lift safely and what depth you've got available for a beam.
I guess it would be two steels each supporting a leaf. When you say depth you mean we need enough headroom to allow for the depth of the beam and a human to pass underneath.
