Rsj installation
12 Aug 2021
Hi
I’ve got 3 rsj’s on each side of my loft to support the new floor and dormer at the rear, my question is how do you install them straight as I’ve got no datum to measure from?
would you measure from the wall plate?
not sure how to go about this
thanks
A laser level sounds just the job! :)
Interesting video for context (starts @ 7:00)
Posh laser levels are self-levelling (a rotary might be the easiest). Water levels work too & v cheap
I mean they might end up running out. So if I’m putting timer joist between they might be 6.5m at the start and then 6.3m and the over end. Or they might be 6.5m centres but running on a angle but the centres are the same.
Well, presumably the existing ceiling joists are square off two walls and parallel off two others. That might help.
