RSJ / Lintel
11 Dec 2020
Hi
I have a 1930's Bungalow and considering changing a window into sliding door and increasing the amount of glass compared to bricks to open the view of the garden.
I am trying to get an idea of indictive costs before I commit costs for structural engineers etc.
There is an existing lintel for the window.
Window frame is W95.6 inch / H 55.6 inch
Wall W136.8 inch H 108.5 inches
Thanks !
If you have a lintel already, and you're replacing a pvc window with a door the same width, then you can reuse the lintel.
It's just a case of removing the brick below the window following the same line down as the window opening.
It's a relatively simple job, the main cost will be the door, and it's very diyable. Technically I think you'll need either a fensa fitter or BCO signoff, but there must be 1000s of doors fitted in this situation which don't have either if you want to live dangerously
Hi
Thanks !
You say the wall is 136.8 inches long? Is this outside wall - outside wall i.e. about two and a bit bricks each side of the window?
It may be difficult finding an engineer that works in lbs/square inch.
Hi
Sorry it's inside wall 136.8inches and external wall is 198.8 inches. Yes it's about 2 and half bricks each side of the window. To avoid confusion I've kept to inches.
