rubber pipe instaed of copper?
If you want to use a hose pipe and jubilee clips carry on mate.
These ARE the pro's (dependant upon your point of view)
http://www.wras.co.uk/PDF_Files/WRAS Note EPDM and hoses rev2 Jan 2011.pdf[/QUOTE]
thank you - that's the sort of info & help i was looking for. it talks about using epdm hose for plumbing situations so clearly its use is acceptable - with the provisos detailed in the article.
If you want to use a hose pipe and jubilee clips carry on mate - just another useless & pointless post - you have made 5 useless and pointless posts in this thread
what precisely is the problem?
The side of the bed someone got out of this morning for starters
- what does that mean?
It was a facetious comment. Ignore it if you don't know what it means.
You originally said you were thinking of using EPDM hose. It is available unbraided and in such form has many uses. As I said previously, you made no mention of overbraiding.
you should start collecting sausage skins, they make excellent hose material. You can join them with some fine stitching.
not sure what this means but it sound like you are short of work if you have the time to write it. if you have any relevant comments please post them
His Mums a Pikie and keeps nicking the copper. :lol:
Another worthless post. :mrgreen:
well I thought it was quite clear, you came asking for advice and I gave you a very reasonable solution. There was no need for your ill mannered reply. If you havent heard of the sausage skin trick then clearly your some kind of cowboy. I suggest you get some proper training.
Right I need a hangover cure.....mmmmm....sausages
:roll: Wow, you're seriously lacking in a sense of humour aren't you...
DIA's suggestion of barrier pipe is a very valid one, it's properly approved for the job and is flexible so it should suit your situation. It'll also be less prone to airlocking than a hose that's naturally quite floppy and will inevitably rise and fall a bit.
think you will find my esteemed colleges from the C.C where pointing out plastic barrier pipe will do the job with less joints ideally just 1 either end coming from isolation valves of course and connecting to your final point hose pipe is for the garden vermin damage/ eventually will perish so my advise is listen to good advice already given and take it
oph i say would very dangerous and buy a pair wellies and a wet suit in anticipation cos without doubt if you use "hose pipe" it will leak.
Itwould be very interesting to hear what the insurance man says after you put in a claim for a few £rand. :lol:
I think that what confuses me is that most DIYers want to look professional. Also they want to sell their homes at some point. Can you imagine what a surveyor would say? What about the embarrassment of having to call in a plumber to make it all work or fix a leak? I'm sure he will be polite but could you stand the patronising remarks?
Sharp intake of breath, "Dear me darlin, married to a farmer are we?"
