- Joined
- 12 Oct 2024
- Messages
- 211
- Reaction score
- 11
- Country
Hi all,
Not a major problem but I need to fix it. At one of the corners, the rubber membrane hasn't been tucked in properly, or has come out somehow. It doesn't seem loose but there is a hole where you can see through to the OSB boards. I would sooner this were closed off.
At the other side of the roof, there is a square attachment that seems to solve this. Possible solutions:
A) just fill the small hole with clear silicone and spread it on the exposed wood. Then no water or bugs can get in. Cheap and easy. Leave the rubber as it is since water falls away from the area in question.
B) remove the black plastic holder strip, pull the rubber membrane down more, then re-attach strip over it.
C) get one of those square things and attach.
D) other?
Please see photos.
Many thanks
D) other?
Please see photos.
Many thanks
