If your floor is a laminat do you have a beading around the edge? If so I have often removed beading and slotted the cable under it, then if required chopped the rear of the beading to fit over the cable. You'll never know its there!
Thanks guys! Adding an extra ceiling sounds like a big job! Good luck.
Is the expansion gap the distance between the edge of the flooring and wall or window. Then the expansion gap looks about 200mm by the window with a wooden flat strip (the beading?) on top and wedged under floor to ceiling windows like a trim.
So perhaps I could run under the beading and then into back of skirting? Beading looks quite thin though maybe 3mm I guess there is a small gap underneath.
The laminate gap is the only real option. Cutting a channel into the ceiling will compromise its integrity, and as it will be a fire barrier between your flat and the one above, you would have to reinstate the damaged area to the same spec as the rest of it (so no good just sticking some filler in there).
The flat wires still need to be skimmed over with plaster or filler (or 'mud' as the Americans call it).
The saving is that you don't need to cut into the wall.
Just painting over the flat wire won't work - it will still be visible.
