If you had a socket and a tv aerial socket next to each other would it cause any interference to the aerial if you ran the cables side by side? Or should they be kept separate?
It won't cause interference, but aerial cables and electrical cables should not be run in the same containment system (conduit, trunking etc, socket boxes.....)
