running cables in new extension
5 Oct 2010
Staffordshire
ive just levelled up my floor joists ready for laying a 25mm plywood subfloor. Before it goes down I need to sort insulation and electric cables.
Im not installing electrics myself but the electrician told me he will 1st fix when the stud wall is in (for walk in wardrobe and rn suite).
The problem I have is I need to lay the subfloor before the stud wall goes in. But because I have noggins between joists the cables cannot be just be slid under the fitted floor.
I cant see the electrician wanting to come for an hour or so to run cables. what options do I have? could i run 2 x twin and earth cables for each socket ready for him, or run conduit with string in place so he can pull cable through?
I want to make sure I get the order right so hes not having to pull up floor when its been put down.
Is this 2 storey extension, above garage extension, ground floor?
Its hard to visualise the overall project.
I would say call the electrician and ask, it may be easiest if he calls round and tells you what he wants
That's what I did for a room I renovated - confirmed where and how to run the cables then the electrician just finished the job. My single storey extension has all the electrics going into the loft space, if you can do same then it'll be out of the way when the floor goes down.
its an extension over an exisiting garage. the ceiling below is fireline plasterboarded. I was planning on leaving it free for access but because of having a new electric garage door fitting had to get it borded 1st.
There is no loft space as we have left the ceuling vaulted. Presumably I could run 2 twin and earth cables for each socket that in having?
Ill msg my electrician. I was holding off for a bit as hes just had a baby
If you know where the sockets are to be situated you could install adequate conduit with 2, (TWO), drawstrings in each one.
The reason for 2 in each is in case he is doing a ring main he may have to pull 1 cable in and 1 cable back out. He should really pull both in together but occasionally this is not the easiest way, so give him an option. The strings can always be pulled out afterwards.
good call with 2 draw strings. didnt think about that
