S
sanj.varah
chrishutt said:Even boilers with zero gas pressure where the gas and air mix cannot really be said to "suck" gas from the gas supply pipe since the appliance inlet pressure should still be at least 18 mbar, although they will operate equally well at lower pressures (which is perhaps what you meant?).
Its difficult to describe this unless you get into absolute pressures and static/dynamic/total pressures. and i don't want to bore the tits off everyone in here.
