Hello
In my home there is one ring main that mostly runs under the floor upstairs, and then loops down behind the dot and dab plasterboard to each socket downstairs.
I'd like to extend the ring and add a socket in the kitchen. So I was wondering how easy it would be to patch into the ring upstairs with junction boxes and then loop a cable down behind the existing plasterboard to the new socket location downstairs.
If you lift the floorboards upstairs, it is usually possible to gain access to the cavity behind the dot/dab plasterboard downstairs?
Once the cable was pushed down behind the plasterboard, presumably I could find it downstairs using a cable detector and drill a hole to retrieve it?
Do you have any advice or tips please
Robin
Robin
