I'm in the process of a loft conversion and as no flooring is down I was going to run the ring main though the upstairs myself. I've received different advise as to whether I have to run the cables through the joists or if I can utilise the eve spaces to the side of the loft that are closed in.
Will I have to use oval PVC conduit even though it will be behind the partition wall.
