    Dismiss Notice
Ideal loft cable routing
Discussion in 'Electrics UK' started by syne, 25 Jan 2017.
  1. syne
    syne
    2 Sep 2013
    28
    Thanks Received:
    Yorkshire
    Country:
    I've looked on the search and around the web but can't get much of a conclusive answer.
    When installing a ring final in a loft is there an ideal/best route for the cable run?
    should it be all under the floor and rise to each socket?
    Run round the rear side of the dwarf walls in a literal ring, clipped to the back of the purlin, to the stud work, in conduit or not? etc etc
    It's a single ring direct from the cu with no spurs, in a very simple loft conversion in a semidetached, no dormer or bathroom.
    Is there an actual method preferred by electricians?
  2. Sponsored Links
  3. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,508
    Thanks Received:
    3,972
    Retired to:
    Country:
    Portugal
    It's up to you really as long as it is safe.
    Is it a house or bungalow?
    There isn't much point having a ring for a loft with the presumed height and waste of cable going back down to the CU.
  4. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,044
    Thanks Received:
    2,061
    Oxfordshire
    Country:
    That how I've always done it. Nice and easy, up behind the plasterboard and into the box.
    PS How can a ring be described as 'literal', either its a ring or it is not.
  5. penguin16
    penguin16
    14 Dec 2016
    67
    Thanks Received:
    9
    Country:
    I assume by literally ring he means a circle.
  6. syne
    syne
    2 Sep 2013
    28
    Thanks Received:
    Yorkshire
    Country:
    It's a house, the reason for a separate ring is, it's a nice straight run down a void to the cu and that has enough spare capacity. It's only a couple of meters further than the point where you'd break into the ring so not too much extra cable wise.
    As for literal ring, well I suppose that's the difference between ring and loop..
    Would you bother with conduit? Or clips to rafters?
  7. seasickstevie
    seasickstevie
    14 Sep 2006
    1,558
    Thanks Received:
    84
    Liverpool
    Country:
    ... perhaps more a 'rectangle' (?)
  8. syne
    syne
    2 Sep 2013
    28
    Thanks Received:
    Yorkshire
    Country:
    Yes, definitely rectangular.
    Out of curiosity what would you guys charge for this?
    Loft is roughly 7x4m with 8 double sockets straight from cu
    A three way switched light for stairs
    A two way switched for 4 down lights
    No access problems, no insulation in yet just framing and floor.
    Only asking because the bc non competent charge is £225 (then + materials cost)
  9. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,044
    Thanks Received:
    2,061
    Oxfordshire
    Country:
    Clip to rafters.
    Its notifiable work, so you probably will save money by engaging a sparky who is happy to oversee your DIY wiring and do the test, cert and notification.
  10. Sponsored Links
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,857
    London
    Country:
    That sounds like a fair-enough reason to choose to have a separate circuit.
    But does not answer the question "why a ring?".
    • Like Like x 1
  12. syne
    syne
    2 Sep 2013
    28
    Thanks Received:
    Yorkshire
    Country:
    Do you mean as opposed to a radial circuit?
    I couldn't give a reason, well not one that would satisfy a sparky...
    From what I've gathered, a ring is arguably yet slightly better than a radial because of the two returns, a bit of redundancy is created should a part of the circuit be damaged.. er maybe.
    Is there a worthwhile reason to not have a ring?
  13. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,044
    Thanks Received:
    2,061
    Oxfordshire
    Country:
    With a radial you use half the copper. And it's pointless to have a ring for moderate loads, like your needs.
    The problem with rings is that that a broken conductor can go for decades without being detected.provided the cable doesn't overheat due to too much current.
    With a radial, you'll know there's a problem straight away.
    EDIT:
    And a radial is more European:D
  14. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,508
    Thanks Received:
    3,972
    Retired to:
    Country:
    Portugal
    Yes.
    The trouble is that redundancy goes undetected and could lead to overload on the remaining circuit.
    Is there a worthwhile reason to have a ring?
    The only reason today for installing a ring circuit is if the first and last accessory is near the supply.
  15. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,857
    London
    Country:
    That doesn't fit well with you deciding that it's OK for you to do electrical installation design....
    It's a struggle to come up with many worthwhile reasons to have one.
  16. syne
    syne
    2 Sep 2013
    28
    Thanks Received:
    Yorkshire
    Country:
    The first/last is near the supply, but that might not be reason enough it seems, likely loading doesn't especially warrant it even if I am a fan of a good ole three bar fire but I do love to feel all intercontinental.
  17. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,857
    London
    Country:
    How many of them do you plan to use in the loft at the same time?
Loading...
Share This Page
