I've looked on the search and around the web but can't get much of a conclusive answer.
When installing a ring final in a loft is there an ideal/best route for the cable run?
should it be all under the floor and rise to each socket?
Run round the rear side of the dwarf walls in a literal ring, clipped to the back of the purlin, to the stud work, in conduit or not? etc etc
It's a single ring direct from the cu with no spurs, in a very simple loft conversion in a semidetached, no dormer or bathroom.
Is there an actual method preferred by electricians?
