Ideal loft cable routing
2 Sep 2013
Yorkshire
I've looked on the search and around the web but can't get much of a conclusive answer.
When installing a ring final in a loft is there an ideal/best route for the cable run?
should it be all under the floor and rise to each socket?
Run round the rear side of the dwarf walls in a literal ring, clipped to the back of the purlin, to the stud work, in conduit or not? etc etc
It's a single ring direct from the cu with no spurs, in a very simple loft conversion in a semidetached, no dormer or bathroom.
Is there an actual method preferred by electricians?
It's up to you really as long as it is safe.
Is it a house or bungalow?
There isn't much point having a ring for a loft with the presumed height and waste of cable going back down to the CU.
That how I've always done it. Nice and easy, up behind the plasterboard and into the box.
PS How can a ring be described as 'literal', either its a ring or it is not.
It's a house, the reason for a separate ring is, it's a nice straight run down a void to the cu and that has enough spare capacity. It's only a couple of meters further than the point where you'd break into the ring so not too much extra cable wise.
As for literal ring, well I suppose that's the difference between ring and loop..
Would you bother with conduit? Or clips to rafters?
Yes, definitely rectangular.
Out of curiosity what would you guys charge for this?
Loft is roughly 7x4m with 8 double sockets straight from cu
A three way switched light for stairs
A two way switched for 4 down lights
No access problems, no insulation in yet just framing and floor.
Only asking because the bc non competent charge is £225 (then + materials cost)
Clip to rafters.
Its notifiable work, so you probably will save money by engaging a sparky who is happy to oversee your DIY wiring and do the test, cert and notification.
That sounds like a fair-enough reason to choose to have a separate circuit.
But does not answer the question "why a ring?".
Do you mean as opposed to a radial circuit?
I couldn't give a reason, well not one that would satisfy a sparky...
From what I've gathered, a ring is arguably yet slightly better than a radial because of the two returns, a bit of redundancy is created should a part of the circuit be damaged.. er maybe.
Is there a worthwhile reason to not have a ring?
With a radial you use half the copper. And it's pointless to have a ring for moderate loads, like your needs.
The problem with rings is that that a broken conductor can go for decades without being detected.provided the cable doesn't overheat due to too much current.
With a radial, you'll know there's a problem straight away.
EDIT:
And a radial is more European:D
Yes.
The trouble is that redundancy goes undetected and could lead to overload on the remaining circuit.
Is there a worthwhile reason to have a ring?
The only reason today for installing a ring circuit is if the first and last accessory is near the supply.
That doesn't fit well with you deciding that it's OK for you to do electrical installation design....
It's a struggle to come up with many worthwhile reasons to have one.
The first/last is near the supply, but that might not be reason enough it seems, likely loading doesn't especially warrant it even if I am a fan of a good ole three bar fire but I do love to feel all intercontinental.
