saab gearbox
3 Mar 2004
my 95 saab is hard to get into 3rd gear, it had a new clutch about 6mths ago. any idea's
I'm no car expert at all, but i had a similar problem a few years ago on a V6 Manual Vectra, and it turned out to be a Planetary Gear in the box.
I would suggest you get it to a gearbox specialist and get them to look at it. The box is likely repairable, but if you keep working it you will probably need a new box..and i assume that will not be cheap on a Saab.
Did the problem start with the new clutch? If so the box is poss. slightly permanantly engaged. Adjust??
