We all know that the gel batteries in an alarm panel should be replaced at regular intervals but what about the battery packs in SABs?
I know that these are a different battery technology (usually NiCAD or NiMH) as opposed to the lead acid types used for panel backup and are usually soldered in but they must have a service life?
Does anybody routinely replace the module/entire bell box after a certain number of years?
On a slighty differnt note, I have an Elmdene 7422-EN SAB module on my desk, most of the connections are obvious, but two are not so:
H- Negative hold off
H+ Positive hold off
BAT- Flying negative lead from internal battery pack
FAULT ? internal self test failure, I guess. Does this switch to +ve or -ve?
REM TST ? Remote test ?
ENG Hold off - by-pass tamper when engineer on site so that cover can be removed without triggering siren
TR ? Tamper return to panel
TS ? Tamper source ? normally connected to H- but could be connected inline with H- of another SAB?
R- -ve trigger
ST- -ve trigger strobe.
Also, what is the purpose of the small wire loop to the left of the LED?
R- -ve trigger
