Safety cut out
in new immersion elements thers is normally one built in that connects to the stat and the element so a reset is not needed on the stat. google it there are images of the cutout on the immersions!
in fact here u are
If you on TLC's web site and search for immersion heaters you will get this
http://www.tlc-direct.co.uk/Main_Index/Water_Heating_Index/Immersion_Heaters_2/index.html
There are two types listed, ones with and ones without safety cut out.
Some immersion heaters have the cut out as part of the base unit and some use a cut out in the stat.
I always put in replacement stats that have a cut out if the original does not have one
If its a NEW installation it must have a safety cut out!
As Taylortwocities said backer immersions are fitted with the cutout on the main base plate not the stat.
