Salamander Pump Problem
31 Dec 2012
Bournemouth
We have had a new Salamander pump recently installed. For 90% of the time everything works fine. But then for example if you turn off the shower to while washing your hair, the pump does not restart when you turn the water back on again. Only resuming after waiting for several minutes. Does anyone have ny idea what could be causing this?
If it's recent, then get the fitter back. It is probably some kind of pressure/flow switch issue but it is under guarantee so get it sorted.
