    Dismiss Notice
salamander pump-turning on and off rapidly when in use
Discussion in 'Plumbing and Central Heating' started by ADONAI, 25 May 2021.
  1. ADONAI
    ADONAI
    3 Jan 2010
    35
    Thanks Received:
    Country:
    Hi
    in the last week the pump is turning on and off rapidly when first used in the morning to provide hot water to the shower .
    after about 10 minutes its then ok.
    Any ideas ?
    A.
  2. Jajodu
    Jajodu
    14 Apr 2017
    129
    Thanks Received:
    25
    Country:
    Sticky flow switch maybe.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. SalamanderPumps
    SalamanderPumps
    2 Feb 2018
    11
    Thanks Received:
    3
    Country:
    Morning... Sounds like your pump is "hunting" - this occurs when a universal pump is installed in a system with a leak. When the pump recognises a pressure drop, caused by the leak, it will activate. You can carry out an isolation test on the pump to determine if a leak is causing the pump to turn on and off. Switch off the water supply from the pump using the isolation valves on the outlet anti-vibration couplers (hoses) attached to the pump. The diagram below should help:
    [​IMG]
    Then leave the pump overnight. If the pump doesn't start overnight then you probably have a leak in the system which is causing the pump to kick in.
    • Thanks Thanks x 1
  5. ADONAI
    ADONAI
    3 Jan 2010
    35
    Thanks Received:
    Country:
    Thanks Salamander but how can that explain it then switching off ? .i can see why that would explain it switching on when you are not using it.
    But its switching off whilst the shower is still running.then it comes on again.
    A.
  6. Sponsored Links
  7. SalamanderPumps
    SalamanderPumps
    2 Feb 2018
    11
    Thanks Received:
    3
    Country:
    If you can give us a call on 0191 516 2002, with your serial number, a member of our Technical Team can run through some tests to get to the bottom this.
    • Thanks Thanks x 1
    • Like Like x 1
Loading...
Share This Page
