The system is fitted as per instructions.
From bottom of tank to highest point in system is 700 mm
Flow under Gravity is 2 l per 30 seconds.
But still pump struggles to kick in for 1 of the showers.
1st shower is bar mixer and works fine.
2 nd is a concealed 2 way divert or, so it has a hand set which comes out the wall low...and works,
But... The fixed main shower head doesn't kick in.
Only if you run shower from handset or from 1 St shower then problem shower works.
The shower is from Victoria Plumb,
And has two outlets and one knob is thermostatic control.
On web site it says minimum .5 bar pressure.
Could this be the cause ?? Ie resistance causing shower flow switches to not kick in??
I've checked everything from pipe sizes to minimum distances and I'm getting readings of over the recommended!!
Or is it possible pump could be border line??
Customer also said today that shower 1 , that previously worked fine , has been fluctuating hot cold!!
On my last visit I turned down cyl stat as it was set to 70'!!
I reduced it to 60, and also lifted the tanks in loft to get me a extra 200 mm height,taking me to just over 700 mm ( base to top pipework) but still same!?
Can rising tanks have a effect on temperature?? As well as pressure obviously?? Because till then 1 St shower was good.
Thanks in advance
Thanks in advance
