Salt coming out of brickwork
31 Aug 2017
Hi just taken plaster off front of house. Acid cleaned it and all old mortar off bricks. Looks great when wet bit all white like salt coming out when dry.
Can i seal it with a wet look sealer as it looks great when wet.
If so whats the best to use.
Thanks Gareth
It's called efflorescence, happens when moisture in the wall comes out carrying salts with it. Either the wall is getit damp or the bricks were laid in the rain and the frogs filled with water/there is water trapped inside the wall. Brick acid cleans it off, I'd consider carefully whether trapping it inside the wall with a sealer is a wide idea
It will go eventually, as long as there is not permanent dampness getting into the wall.
