HI
I'm looking for some help as I'm confused. I have installed a Salus RT500RF and connected the receiver to the boiler as:
Boiler connection ------> Salus Receiver
Lr ----> NO
Ls ----> L
Ns ----> N
I have also a 'Link' from the L to COM on the Salus Receiver.
The Receiver has a red light on the front. When the programmer calls for heat the green light comes on.
The issue. When there is no heat called for (no green light on the receiver)the boiler still fires and supplies CH unit until I either remove the NO or COM cable. It seems that the switch on the Receiver isn't opening when the no heat is required. I have created a manual switch between the COM and the NO connection and when I open it the boiler shuts off.
I had an WB Digistat Optimiser installed but that failed. I have removed the ribbon cable from the boiler control side of the programmer but left it in the boiler disconnected. I'm not sure if that would cause a problem.
Any ideas or thoughts?
Thanks in advance.
Matt
Lr ----> NO
Ls ----> L
Ns ----> N
Thanks in advance.
Matt
