samsung rs21 wireing loom problem
19 Oct 2009
Lincolnshire
hi
we have had the usual problem of our fridge freezer icing up, we have gone down the road of defrosting it ourselves countless times & have now bought the 5 part back panel defrost kit.
we got all the new parts in with no problem at all until it came to the changing of the wireing loom to the fan,( we had to do this because our model is about 10 yrs old) we now understand that this means taking the old wire & replacing the new wire with it. the problem we have is that we took the wires out of the little plastic housing foolishly because at the time we didnt know what we were doing.
the old wires are grey yellow & black, the new wires are red white & black so does the black still correspond to the black? & what does the yellow & grey correspond with? here is a picture hopefully
thank you for anyones help
sarah
so sorry for the size of the picture, i used tiny pics & selected the code for forums so i dont know what went wrong.
sarah
Does the new plug fit in the existing socket, Sarah?
Try with the fridge disconnected. If it does fit, I'd give it a try if it was mine.
The plugs should only fit in the one way.
John :)
no the other end of the new loom doesnt fit into the plug in the back of the fridge that is why we had to change it to the old loom.
many thanks for your reply
sarah
I see - so the obvious thing is to splice the new cable onto the plug of the old one.......personally I'd have to trace the new cables back into the defrost unit to satisfy that they were going where they were intended!
I'll bale out from this one Sarah - maybe give the supplier a call tomorrow if no one else comments.
Be lucky!
John :)
