Sanding between coats
5 Feb 2007
Lincolnshire
Hello,
I'm currently painting the walls in a bedroom and have found that when sanding down the very first coat of emulsion, in preparation for the second coat, small patches of the old very dark wall colour show through where the wall is slightly bumpy. I am using P120 sandpaper. Am I simply sanding too hard or should I maybe apply a couple of coats of emulsion the first time round, without sanding in between, just to build up a thicker layer of paint?
Thanks for your help.
R
120 grade..thats a bit much for emulsion walls..stick to an 80 grade, the orange peel finish with the new coats of paint wont justify using 120 grade..I bet its clogging up a lot too
You might be rubbing down to hard or you may just be exposing higher areas
Use 80 grade and a sanding block, rub down in a circular motion, give the wall a good once over and then do your first coat to see how it looks..then either do a bit more rubbing down or filling as neccessary
B&Q Colours Magnolia, nothing special.
Do you think it's necessary to sand down between every coat or perhaps just the last one prior to applying the final coat?
Why are you rubbing so hard? All you should be doing is taking off the tiny rough bits.
You do not need to rub down between coats when using Matt or Vinyl Matt.
If you use Soft Sheen or Silk in the same day then there is also no need to rub down.
