Sanitary Silicone
17 Feb 2008
Berkshire
Will this be ok to use outdoors to seal between concrete garage sections (joins)
it is to seal the joints after construction. was hoping for a cheaper way as i imaging it will take a fair few tubes
But then again using the wrong one will cost more in the long run
I've just looked at a tube of frame fix in my van, it says coverage 6mm bead - approx 11 linear metres.
So, 6'6" is about 2m therefore, one tube should do 5 panels easily.
25 panels x 6 tubes (to be on the top side) of Dow Corning or similar works out at about £25.00 in product, plus a few quid for an applicator gun....1/2 a day to do the job & 30 quid'ish in materials.... :D
