    Dismiss Notice
Satellite Cable through cavity wall
Discussion in 'Audio Visual' started by DSA, 12 Nov 2009.
  1. DSA
    DSA
    29 May 2005
    54
    Thanks Received:
    3
    Country:
    I am looking into DIY installing freesat HD, and am currently interested in the drilling through the wall part. The proposed hole would be drilled though a cavity wall of 100/100/100 construction. Should I be concerned about bridging the cavity with the cable? (Normal precautions of angled drill/sealed hole/drip loop would be taken). There is alternatively a possibility of drilling through a soffit board and fixing the cable to skirting inside the room. This would be a lot more work, but would it be preferable to the first option??
    Also, is it better to opt for a 60cm dish for the south of england/south midlands, or will a 45cm dish be perfectly adequate??
    Many thanks.
  2. Sponsored Links
  3. Ltnman
    Ltnman
    16 Apr 2008
    146
    Thanks Received:
    2
    Bedfordshire
    Country:
    Lost count how many cables I have fitted through a cavity over the years as a telephone engineer. No one has ever complained.
  4. ericmark
    ericmark
    27 Jan 2008
    16,207
    Thanks Received:
    1,467
    Llanfair Caereinion, Nr Welshpool
    Country:
    I would agree. Drill hole do not remove drill bit but disconnect from drill. Tape cable to drill then draw through. This way insulation does not fill gap when you take drill out. SDS drills are great as spigot slightly smaller than drill so room for tape. At least with size I use.
  5. Chukka63
    Chukka63
    14 Oct 2009
    903
    Thanks Received:
    81
    Country:
    beware the drill bit may be hot :LOL:
  6. Atilla
    Atilla
    21 Nov 2007
    569
    Thanks Received:
    35
    Lancashire
    Country:
    what a dumb piece of "advice" .............. use the correct tool
  7. DSA
    DSA
    29 May 2005
    54
    Thanks Received:
    3
    Country:
    With a pebbledash style render on the outside, would you advise drilling from the outside or the inside?? What hole diameter should I drill for shotgun cable....and what shank size will this (x min 350mm long) drill bit equate to? (will it fit in a 10mm chuck?)
  8. Chukka63
    Chukka63
    14 Oct 2009
    903
    Thanks Received:
    81
    Country:
    aint you got the tv working and watching yet???.lol.just drill a hole from outside to in and push the cable through. :LOL:
  9. DSA
    DSA
    29 May 2005
    54
    Thanks Received:
    3
    Country:
    :D I like to have all the information to hand before I buy! Have just decided to go with a 60cm dish, so I'll order that off ebay later. Will need to pop down screwfix to get a new drill bit, so which size should I get?!
  10. Sponsored Links
  11. richjamesw
    richjamesw
    6 Feb 2009
    52
    Thanks Received:
    Nottingham
    Country:
    get one a bit bigger than the cable therfore you wont struggle trying to feed it in.................logic
  12. ChrisFrost
    ChrisFrost
    26 Aug 2009
    1,025
    Thanks Received:
    213
    Cheshire
    Country:
    er, not to state the bleedin obvious but... if you have to ask about the size of the drill bit are you sure you should be tackling this job yourself?
  13. foxhole
    foxhole
    14 Mar 2006
    16,207
    Thanks Received:
    1,812
    Kent
    Country:
    No one seem to have mentioned it , so drill at slight upward angle from outside to discourage any rain from running in and seal the cable with a little silicon.To crosss a cavity I useually poke a straight piece of coathanger wire [400mm should be enough]into the end of cable so it guides it across the cavity.
  14. westentertainer
    westentertainer
    3 Jan 2010
    4
    Thanks Received:
    South Glamorgan
    Country:
    never drill from outside,,its easier to repaire outside than plaster inside
  15. opps
    opps
    16 Jun 2006
    4,336
    Thanks Received:
    670
    London
    Country:
    Not always true, surely pebble dash or old brick faces are more likley to pop than soft, sound plaster? Also outside in implies less dust in the house.
  16. westentertainer
    westentertainer
    3 Jan 2010
    4
    Thanks Received:
    South Glamorgan
    Country:
    so how do we test from outside for cables or pipe work,,i have been in the satellite buisness for 20 years ,and now am a team manager for one of the largest satellite /aerial company in the uk .and if one of our engineers drilled frrom outside in they would be in trouble if they hit a cable or pipe
  17. opps
    opps
    16 Jun 2006
    4,336
    Thanks Received:
    670
    London
    Country:
    Your last point is valid but it isn't implied by your previous point.
    I would be concerned about anyone drilling without checking both sides before hand!!!
Loading...
Share This Page
